I am trying to run a model with the Apply Symbology from Layer tool against multiple feature classes, some using a simple symbol and others based on a field. The tool works when there is only a simple symbol. When symbology is based on a field the output never comes out correct. Things I've checked for:
Any thoughts on a resolution? This is a process that will be repeated several times and we would like to avoid manually setting the symbology for each feature class.
Thanks!
Kyle
Pictures for your model and your experiments will be helpful.
Here is a picture of the model.
Do you try this model as a tool ? ( from Arc Toolbox)
I am no wonder that model not change symbol of feature class in classified depend on field.
but I am wonder that is change simple symbol!!
How it is done?
because to change layer symbology, you should add that layer in TOC and run tool not inside model.
