2012 Aerial Images
1710
07-18-2014 06:21 AM
KatherineColwell
I'm looking for fairly recent (anywhere from 2012-present) aerial imagery of WV.  Does anyone know of a good site to pull/purchase from?  I'm having difficulties finding imagery beyond 2011.
IanMurray
Honored Contributor
Hi Katherine
NAIP Imagery only goes up to 2011 in WV(so far), so no luck there(though they should be flying it again this year, but it could be a while before the products are available).  Depending on how large the area you need to find imagery for, selected areas were flown in 2012 by the sheriffs association for populated areas with 4in resolution.
http://wvgis.wvu.edu/data/dataset.php?ID=437
If your project is fairly small in scope, some counties do fly their own imagery so you could try to get it from them.
Hope this helps you out.
KatherineColwell
No luck with the sheriffs association. Thanks anyways!
Mapperzmap
Only to 2011 [PDF]
See the flight paths and upgrade resolution plan
http://www.vita.virginia.gov/uploadedfiles/vita_main_public/unmanaged/isp/vbmp/2009-2011/vbmp%202011...
more info at
Orthoimagery
