Converting from UTM 37N WGS84 to ADINDAN ?
9897
11-05-2014 02:04 AM
LoicRagas
Hi All,
I would need to convert some well locations from reference datum WGS84 to ADINDAN using the Arctool box.
I have three options given:
Adindan_To_WGS_1984_1
Adindan_To_WGS_1984_4
Adindan_To_WGS_1984_7
I understand from precedent discussion that for wells located in Lac Tana Ethiopie area I should be using the option Adindan_To_WGS_1984_4.
However when I apply this method it doesnot result well as my points initially in WGS84 remain inchanged.
Would you know whether I should first edit the method of transformation and what should be changed ?
Where to find the correct parameters (see attachements for the actual I have) to edit and update Adindan_To_WGS_1984_4 ?
Thank you for guiding me on this.
Best regards,
Loïc, France.
NeilAyres
They are probably changed, you just don't see it.
Open a brand new ArcMap session, add your Adindan based output. Add the original. When the warning comes up about different datums, just click Ok, ie ignore it.
You should have 2 sets of points, displaced by approx. 280m.
