Network Analyst Route - How to Report Cost (Time) from Length and Speed
2780
11-29-2017 06:56 PM
DerekFord
Hi Everyone, pretty simple analysis I believe.. Single road layer with three different road types/speeds. How to compute routes and report travel time in attribute table?
Data attached if you'd like to try it out.
DerekFord
I've got it reporting minutes now, just had to add "minutes" field and calculate from speed and length of each road segment. Now how to have the route report both length and minutes? I can only figure out how to report each separately (impedence = length OR impedence = minutes).
JaySandhu
If you have impedance attributes for both length and time added to your network dataset, then when you solve for one, you can accumulate the other and it will get reported as well. On the route analysis layer properties, click on the Accumulation tab and check on other attributes you want to report.
Jay Sandhu
