Site Selector App draws 1km buffer. Units set to Miles.
647
11-28-2017 10:25 AM
PhilLarkin1
This has been verified on a local implementation and ESRI demo sites. It has also been documented on GitHub repo.
Request sent to GeometryServer probably needs the geodesic parameter set per API doc
If geometries are in geographic coordinate system, then geodesic needs to be set to true in order to generate a buffer polygon using a geodesic distance. bufferSR input parameter will be ignored when geodesic is set to true.
Thanks to Robert Scheitlin, GISP for his suggestion here: https://community.esri.com/message/655101-re-buffer-not-accurate?commentID=655101#comment-655156
GitHub Post:
Allow for decimal values for min/max buffer distance parameters · Issue #218 · Esri/site-selector · ...
For anyone hoping to overcome this and have geometries in a geographic coordinate system, modify the code below. I have not tested this in production but seems to work in test.
roughly line 1270 js\library\widgets\siteLocator\siteLocator.js
params.geometries = [this.featureGeometry[this.workflowCount]];
 params.unit = GeometryService[this.unitValues[this.workflowCount]];
//Add this:
 params.geodesic = true;‍‍‍‍‍‍‍‍‍‍‍‍
Chris Buscaglia
