Crowdsource Reporter and URL parameters?
6335
11
02-06-2017 07:58 AM
ChelseaRozek
MVP Regular Contributor
Is it possible to use URL parameters to open to a specific feature and/or map within Crowdsource Reporter? I'm using the template from GitHub.
This would be helpful for us because we would like to send out an email upon request creation with its details as well as a hyperlink to the feature. Also, I'd like to be able to direct people to the correct map, example: a hyperlink from the Parks and Rec website directly to the map where they can report Park facility issues.
Tags (1)
NataliyaLys
Thank you Aziza.
While it works, user still needs to click on the ''Proceed as Guest" and then the request gets pulled up. It would be nice if a request gets open right away, without user needing to click on 'Proceed as Guest'?
Thanks Nataliya
JackiePhipps1
We can use the above method to change the focus of the map, but is there a way to get it to zoom in on a feature?  For example, we want to zoom in around a school in the crowdsource report not just shift the view. Here is the crowdsource report we are trying to update: https://littleton.maps.arcgis.com/apps/CrowdsourceReporter/index.html?appid=7b63ec731c2d4fe9b636a5b8...
