Capital Project Plans Solution - Database error has occured
742
05-08-2018 01:09 PM
Loprz
I have recently deployed the Capital Project Plans Solution into our 10.6 ArcGIS Portal site. I used the ArcGIS Solution Deployment tool in ArcGIS Pro 2.1.2. All goes well and I am able to look at the applications, however when I try to create a new feature within the application I receive the following error. Captial Projects Planning database error popup
When I view the error in ArcGIS Server Manager logs I see the following messages:
Server Error log showing. 0 : The column index is out of range: 31, number of columns: 30.
This was from three attempts. The error occurs after completing the polygon.
I can circumvent the error by recreating the view from the hosted feature layer.
Can you assist me in identifying which troubleshooting tips that I can try next?
