Will OpenJDK work with ArcRuntime 10.2.4 JAVA?
1787
04-22-2019 11:08 AM
TravisJowell1
ArcRuntime 100.x (Java) is supported with OpenJDK. Is the previous version 10.2.4 compatible or was it just not certified at the time of release?
MarkBaird
10.2.4 was never certified against OpenJDK so we can't support you directly using this.  However I've used it with success.  The reason we've started supporting OpenJDK at 100.x is due to the recent changes to Oracle licensing.
TravisJowell1
No worries, ahem, we are using it for the same reason. Was seeing if there were any major pitfalls as it wasn't as pertinent to use it when 10.2.4 was released.
MarkBaird
Theoretically you shouldn't see any issues and I've used it myself too. It just isn't officially supported as it was never tested against it.
Could now be the time to make a step into the world of JavaFX development and 100.5?
