widgets/j2ee
2785
04-03-2013 08:24 AM
lifeEsri
Salut
existe il des widgets développer en j2ee comme ce qu'on trouve dans le flexviewer
Hello
are there any widgets developed in j2ee
MarkBaird
We are generally encouraging developers to move away from Web ADF development as there are improved web API platforms out there which scale better and give you access to the latest ESRI developments.
http://events.esri.com/uc/QandA/index.cfm?fuseaction=answer&conferenceId=2F6DC1A1-1422-2418-883C3868...
I'm not really the right person to advise on IDEs for Java development on web ADF, but this page should give some ideas:
http://resources.arcgis.com/en/help/system-requirements/10.1/index.html#/ArcGIS_Web_ADF_Java_Platfor...
If you need forum help on the subject, then you will get better answers going to the ArcObects forum.
http://forums.arcgis.com/forums/20-ArcObjects-SDKs
Mark
MarkBaird
Hi
What product is your question about?  Are you using the JavaScript API or Runtime SDK?
Thanks
Mark
lifeEsri
Hi
Thanks
Mark
thank you 🙂
I'm using SDK  (j2ee application with flex animation)
MarkBaird
I've replied to your other post which should point you in the right direction.
http://forums.arcgis.com/threads/81312-arcgisServer-j2ee
Let me know if you need any more help.
Mark
lifeEsri
Thank you very much Mark for your help.
I want to know if I use web adf for java I can use in this case apis for flex
and if this is not the case how can I use flex with java in eclipse and thank you
MarkBaird
Mark
