UniqueDesignation Message Property Not Working in 10.1.1
4005
01-23-2013 05:29 AM
CarlosColón-Maldonado
Can someone confirm that the Message object's property of "UniqueDesignation" that worked in version 1.0 no longer works? The Javadoc appears to state that it is suppose to. I executed an existing application that performed the following operation and displayed the symbol's label successfully prior to the upgrade, but no longer:
      message.setProperty("UniqueDesignation", "Mad dog");
I'll be happy to submit a bug report if it's the case.
[ATTACH=CONFIG]21000[/ATTACH]
[ATTACH=CONFIG]21001[/ATTACH]
MarkBaird
We've had a look at what is happening here and can confirm there is a bug.  The code you used at 1.0 for your Unique Designations will not display the label.
There is however a workaround.  If you change your line of code as follows it will work:
[INDENT]message.setProperty("uniquedesignation", "Mad dog");[/INDENT]
It a case sensitivity issue.
This something we will consider carefully in terms of the fix we apply.
I hope this helps in the short term.
Mark
by Anonymous User
Not applicable
Original User: mbaird
We will investigate to see what is happening...
Mark
MarkBaird
Mark
