Two WmsDynamicMapServiceLayer ?
1653
04-12-2017 02:26 AM
MohammadAlmalt
Is there a way to put two WmsDynamicMapServiceLayer on top of eachother where both are transparent ?
nita14
Mohammed,
why don't you create two instances of WmsDynamicMapServiceLayer pointing to differents wms service endpoints?
Regards,
Adam
MohammadAlmalt
Hi Adam,
I did that, but only 1 layer is displayed at a time.
String url = "first url";
WmsDynamicMapServiceLayer wmsLayer =
            new WmsDynamicMapServiceLayer(url, new String[] { "0"});
        wmsLayer.setTransparent(true);
        wmsLayer.setImageFormat("png");
        wmsLayer.setVisible(true);
        wmsLayer.setOpacity(0.99f);
        layers.add(wmsLayer);
url = "second url";
wmsLayer =
When I comment the first layers.add(wmsLayer); then the second one is displayed on the map
When I comment the second layers.add(wmsLayer); then the first one is displayed on the map
When I want both to be displayed it does not happen
Is there a solution?
nita14
Mohammad,
As I said - " create two instances of WmsDynamicMapServiceLayer",
create
WmsDynamicMapServiceLayer wmsLayer1  = new WmsDynamicMapServiceLayer(url, new String[] { "0"});
and WmsDynamicMapServiceLayer wmsLayer2 = new WmsDynamicMapServiceLayer(url, new String[] { "0"});
then set visibilty to those. As so far you override the first layer by the definiotion of the second one.
Regards,
Adam
