The map loads in gray
1796
02-27-2023 12:33 PM
stiven
The map is coming out in gray and it does not show me the streets, the sdk that I currently have is 30  and this is the version of Sdk arcgis
api 'com.esri.arcgisruntime:arcgis-android:100.8.0'
I attach evidence:
can someone help me please
PriyankaRupani
It seems to me, you are trying to load a streets basemap, per your question.
So I tried setting a streets basemap to mapView and load the mapView using
"com.esri.arcgisruntime:arcgis-android:100.8.0"
android sdk version, and it does load fine. I used an android 30 emulator to test this.
Below is the code snippet.
// inflate MapView from layout
mMapView = findViewById(R.id.mapView);
// create a map with the a topographic basemap
ArcGISMap map = new ArcGISMap(Basemap.createStreets());
// set the map to be displayed in this view
mMapView.setMap(map);
mMapView.setViewpoint(new Viewpoint(34.056295, -117.195800, 10000));
MarkBaird
I've asked someone from the Android team to look at this, but can you share the code you are using to add the basemap.
PriyankaRupani
