Support for Eclipse Juno?
1277
07-26-2012 10:36 AM
DavidBurnett
I tried to install the eclipse plug-in for ArcGIS Runtime SDK for Java 1.0 after I had upgraded my Eclipse to Juno. It failed on a requirment for VE(visual editor). Unfortunatly I needed the glassfish plugin for another Java project; which at Juno doesn't support VE.I see that your highest support currently in indigo. Are there plans to support Juno?
EricBader
Honored Contributor
Yes, Juno is on the list to Officially support as soon as possible.
Right now , I use Juno exclusively with the runtime sdk plug-in 1.0. It runs like a charm, no problems. I don't use VE anymore, though. WindowBuilder Pro works really well in Juno, as an alternative.
I hope this helps.
