Request for Java 17 build for given jars
1515
01-03-2025 12:56 AM
SaurabhDudhe
Hello
We are consuming below set of jars (java package) from ESRI. We wish to have latest upgraded jars over Java 17.
Here is the list :
1. esri_mo23.jar
2. esri_mo23cad.jar
3. esri_mo23img.jar
4. esri_mo23res.jar
5. esri_mo23rpf.jar
6. esri_mo23vpf.jar
7. arcgis-natives-win32.jar
8. arcims_jconnect.jar
9. arcobjects.jar
10. crs_res.jar
Can you please help us.
MarkBaird
Can you describe a little more about what you are using these for?
From the name of the files, I can see you have jar files for ArcIMS and MapObjects which are products I last used 20+ years ago and are no longer supported.
If you tell us more about what these are used for, we can assist you with suggestions on migrating to a supported set of tooling.
SaurabhDudhe
Thanks @MarkBaird  for the reply.
We have a legacy product in which we use these jars. We have little knowledge around this.
We wish to upgrade the product to Java 17 and hence  we need java 17 build (or compatible version at least) for mentioned jars.
