Packaging for Runtime
1800
08-10-2011 10:32 AM
MatthewKnight
I installed Desktop Beta 1, however when creating map packages I do not see the option to create packages that have Runtime Support enabled (something I have seen demonstrated).
Packages I created are not loading as LocalArcgisDynamicMapServiceLayers.
MichaelBranscomb
Esri Frequent Contributor
Sounds like it's just a case of switching on ArcGIS Runtime support in the ArcMap options:
1. Click Customize > ArcMap Options...
2. Select the Sharing tab
3. Under Packaging, check the box to "Enable ArcGIS Runtime Tools".
Cheers
Mike
MatthewKnight
Thank you, that fixed the problem!
But now a new one:  is there a plan to include support for packaging mosaic layers?  Inability to use mosaic datasets in runtime would be very disappointing.
MichaelBranscomb
There are two elements to this:
(1) Basic mosaic dataset support within the existing local map service = we hope to support this in the first release at 10.1 (but unfortunately cannot guarantee it at this time).
(2) Providing local image service support (for which the source may be a mosaic dataset) = we aim to support these in an off-cycle release some time after the first release.
Unfortunately I can't be more specific at present.
Cheers
Mike
