java runtime sdk, support for Bing Base maps
2681
05-01-2012 03:16 PM
KevinNetherton
Combing through the various runtime sdk's it looks like some of them support using Bing Basemaps while others don't.  Unfortunately it looks like the Java runtime sdk is one of the runtimes that does not support Bing Basemaps.  Are there plans add the ability to use Bing Basemaps with the java runtime sdk? If so approx timeline would be wonderful.  If not would also be useful to know!
MaryHarvey
Esri Alum
The ArcGIS Runtime SDK for Java will support Bing Basemaps at version 1.0. There will be a BingMapsLayer class and code that you can run/copy in the Sample Application. Mary Harvey
