Improve performance on UHD display
605
08-24-2016 04:05 AM
GabrielUnmüßig
I'm trying to run a map application on a 4k display (resolution 3840 × 2160) but the frame rate is very low.. The map is nearly unusable. The sample application in the Runtime SDK has the same problems, even on the "Basic Map" demo.
I'm using the 10.2.4 Runtime on Windows 10 and the RenderEngine is DirectX. OpenGL crashes with an access violation.
Is there a way to improve the overall performance of the Runtime?
Greetings,
Gabriel
