how to use arcpy in arcgis runtime java
5710
05-29-2015 06:56 PM
neerajbharti
I have to use arcpy in arcgis rumtieme java. but unable to use it.........................
can anyone suggest me how to use it.???
EricBader
Honored Contributor
No, there is no direct way of using .pyt files.
EricBader
Honored Contributor
You can start by reading the "Perform Analysis" section of the Guide and looking at Geoprocessing and Run a Geoprocessing Task.
Depending on the type of arcpy functions you need to use, you can run the arcpy script in ArcMap, export the results to a geoprocessing package, and open and use it in a Runtime application.
Some gp tools and models are not supported in Runtime, so be aware.
I hope this helps
neerajbharti
Thanks Eric. but is there any way to use .pyt (python toolbox) (without gpk or mpk ) as I see  the .pyt files in installation folder of arcgis runtime java.
EricBader
Honored Contributor
