How to set Point Graphic feature in Geoprocessing Parameter
1073
10-11-2017 03:37 AM
Siva_SankaraReddy_T
I am tried  to run  Buffer.gpk in ArcGIS Runtime for Java 100.1.0 Application. I have Three parameters(Graphic, Distance,output).How to Pass input Point Graphic into GeoprocessingParameters using subclasse GeoprocessingFeatures(Corresponds to GPRecordSet or GPFeatureRecordSetLayer parameter types). please help me.
EricBader
Honored Contributor
Hi Shiva,
Try something like this (pseudo code!):
//create the feature data
List<Field> fields = new ArrayList<>();
fields.add(Field.createString("something", "something", 50));
FeatureCollectionTable table = new FeatureCollectionTable(fields, GeometryType.POINT, SpatialReferences.getWgs84());
List<Feature> features = new ArrayList<>();
Map<String, Object> attributes = new HashMap<>();
Point point0 = yourGraphic.getGeometry();
features.add(table.createFeature(attributes, point0));
table.addFeaturesAsync(features).get(10, TimeUnit.SECONDS);
GeoprocessingFeatures gpFeatures = new GeoprocessingFeatures(table);
parameters.getInputs().put("InputFeatures", gpFeatures);
Let us know if this helps....
