How to log map/image size?
4264
04-27-2015 06:51 AM
nita14
Does anybody know how I can log the map/image size (from any layer in the map) as I navigate the map using ArcGIS Runtime for Java?
Thank you!
EricBader
Honored Contributor
This is interesting. There might be a way, but can you give more details on your use case?
EricBader
Honored Contributor
nita14
Hi Eric,
  I will write you a private e-mail describing my case. As so far, I decided to use Fiddler.
