how to Create Mosaic
939
11-06-2017 09:47 PM
Siva_SankaraReddy_T
I created gpk using Add Raster To Mosaic Data set Tool, it has three parameters:Mosaic Data set, Raster Type, Input Data. In the code, for first parameter i used Geo-processing Raster, for Second Parameter  i used Geo processing String,but  i got error while passing second parameter. Please help me. how to create Mosaic in Arc GIS Runtime for java 100.1.
Tags (1)
EricBader
Honored Contributor
Hi Shiva,
Sounds like you're on the right path.
What does the error look like, exactly?
FYI: At 100.2, you'll be able to use the MosaicDatasetRaster API to create mosaics and add rasters to them, without having to use the Local Server. The release is in a few weeks.
