How to add symbol image to arcScene using local .png or .img file?
1593
01-31-2021 09:57 AM
VanyaIvanov
I used this code but it doesnt work:
GraphicsOverlay graphicsOverlay = new GraphicsOverlay();
sceneView.getGraphicsOverlays().add(graphicsOverlay);
// An image file on the hard drive.
File file = new File("C:\\Users\\user\\Documents\\IMG1.jpg");
String localUri = file.toURI().toString();
PictureMarkerSymbol markerSymbol = new PictureMarkerSymbol(localUri);
markerSymbol.setHeight(100);
markerSymbol.setWidth(100);
markerSymbol.loadAsync();
com.esri.arcgisruntime.geometry.Point symbolPoint = new com.esri.arcgisruntime.geometry.Point(20, 20, SpatialReferences.getWgs84());
Graphic symbolGraphic = new Graphic(symbolPoint, markerSymbol);
markerSymbol.addDoneLoadingListener(() -> graphicsOverlay.getGraphics().add(symbolGraphic));
MarkBaird
If you are working with a file on the local OS, you don't need a full URI format, you can just use the file on its own.
I just tried this out with the following code:
    mapView.getGraphicsOverlays().add(graphicsOverlay);
    PictureMarkerSymbol markerSymbol = new PictureMarkerSymbol("./FireStation.png");
    markerSymbol.addDoneLoadingListener(() -> {
      System.out.println("loaded status " + markerSymbol.getLoadStatus());
      if (markerSymbol.getLoadStatus() == LoadStatus.LOADED) {
        // use the symbol
        Point point = new Point(0,0);
        Graphic graphic = new Graphic(point,markerSymbol);
        graphicsOverlay.getGraphics().add(graphic);
      } else {
        // error state as it didn't load
        System.out.println("Failed to load: " + markerSymbol.getLoadError().getCause());
Does this work for you?
MarkBaird
        // use the symbol
      } else {
VanyaIvanov
Thank you! It works.
MarkBaird
An alternative solution would be to construct the symbol directly from a JavaFX image.  If you are already using the image elsewhere in your app for example, you could do this:
    Image image = new Image("file:FireStation.png", 100, 100, false, false);
    PictureMarkerSymbol markerSymbol = new PictureMarkerSymbol(image);
