Get wkt from ESRI Geometry
3193
03-14-2019 05:34 AM
AgencyDeveloper
I am using the rest api (Query (Map Service\Layer)—ArcGIS REST API: Services Directory | ArcGIS for Developers ) to query a layer. I get the geometry as
Polygon:
Ring0:[-119.152450421,38.4118009580001],[-119.31882507,38.5271086230001],[-119.575687063,38.7029101290001]...81 more...
How do I convert it to wkt? Is there a java library for that, I couldn't find it in the sdk.
nita14
Have you tried to use Geometry| arcgis-java to get gemeotry in WKT?
Hope this helps,
Adam
