Features supported by ESRI
3395
04-23-2013 05:39 AM
NP
Hi All,
I am very new to ESRI tools and need help.
We are reviewing options for a web based map application with the features below.
a) Multiple users with different view of the map for each user based on the users location
b) To show shape files specific to the user that logs in and selects.
c) Capabilities for editing shape files (points/lines/polygon).
d) Java API's to support development of additional features.
Does any of ArcIMS / ArcGIS server (online) support these?
Any answer or direction is greatly appreciated.
Thanks...
MarkBaird
Hi
For web based mapping applications we've got a few options which may be of interest to you.
You should take a look at the ArcGIS Online capabilities for "cloud" based solutions
http://www.esri.com/software/arcgis/arcgisonline
If you want to develop your own applications (which can consume either your own hosted services or ArcGIS Online services and webmaps), then you need to look at one of the web APIs we offer.  We have APIs for FLEX, Java Script and WPF.
There are some links below and forums for each of these products.
General link : http://www.esri.com/getting-started/...rs/get-started
- Flex : http://www.esri.com/getting-started/...t-started/flex
- Java Script: http://www.esri.com/getting-started/...ted/javascript
There are loads resources available on all of these products.
Let me know if this helps.
Good luck
Mark
MarkBaird
Hi
Good luck
Mark
EricBader
Honored Contributor
Mark nailed it.
Since you asked about Java as well, it may be worth mentioning that there is also the ArcGIS Java Web Services (AgsJWS) API for enterprise Java development:
http://resources.arcgis.com/en/help/soap/10.1/index.html#/java/01vp00000044000000/
