Extract polygons from shapefile
1410
02-28-2024 02:37 AM
blackstorm
hello community,
I'm new to ESRI Gis data processing, I'm reading a shapefile and would like to extract from it polygons, but all I get is points
I'm using esri api (code written in scala)
Thank you
Tags (3)
MarkBaird
Can you confirm that you are using the Maps SDK for Java and if you are the version you are using.
If this is the product you are using can you share some code so I can see what you are doing?
It would also be good to understand the type of app you are writing.  Is this a client side application or something server based?
