error on my first try using asrcgis plugin
4125
12-18-2014 10:58 PM
TikaRiskawati
when i run my project, it says :
Java version : 1.8.0_25 (Oracle Corporation) amd64
Rendering engine : DirectX
java.lang.RuntimeException: Unable to find runtime installation. Searched following places:
F:\Skripsi\coba1
Failed to read environment variable ARCGISRUNTIMESDKJAVA_10_2_4
i don't know what happen, please help me to find solution.
VijayGandhi
I guess you are using Eclipse and that it has been running since before the installation.
You could restart (Exit and then start, instead of File->Restart) Eclipse - that will pick up the environment variable.
