Creating TOC with Runtime
2061
12-21-2011 10:55 PM
MartinRick
right now I am working on a small demo map viewer with the runtime. Unfortunately I have problems to create a legend / toc for the currently loaded data. I found a JLayertree.java in the samples, but this class seems not to be able to deal with group layers.
Is there any agenda for a standardised legend/toc control or does anyone have a sample how to create such a GUI component?
Cheers
Martin
RalfGottschalk
Hi Martin,
We are planning on including a TOC sample in the Tooklit for Final.
CarlosColón-Maldonado
Hi, I'm just trying to follow-up with this thread. TOC is a functionality I'm interested in.
I just installed the final release of Runtime and there doesn't seem to be a sample that implements TOC functionality. I browsed through the toolkit for naming convention-type functionality and I can't see it there, either. Did this happen?
Thanks in advanced,
Carlos
EliseAcheson1
Hi Carlos,
At Final there is a JLegend component in the toolkit which implements TOC functionality. As it is in the toolkit, the source code is available and a sample called 'Legend (Online)' is in the Java sample viewer under 'Toolkit'.
I hope that helps,
~Elise
Got it, Thanks, Elise!
Carlos
