Creating Polylines on Graphiclayer
1175
01-12-2012 04:41 AM
MartinRick
I try to create polylines on a GraphicLayer in order to measure distances. As long as the Spatial Reference of my data is WGS 84 it works more or less, but when using another Spatial Reference (here Webmercator) I can create points by clicking into the Map, but the line segments get drawn at the equator. Does anyone else have the same problem?
Cheers
Martin
JohnHauck
This sounds like an issue with the SpatialRefernce that's being used for the line. Could you post some sample code to show the workflow?
