Can you use a featureserver as a map layer in the Runtime SDK for Java?
5303
04-13-2015 10:30 AM
TedJacobi
I have a FeatureServer already made and on the REST server (I think that is correct terminology), I want to use the FeatureServer in a map application. It consists of multiple trails that I want to display on a basemap. I made the simple map from the online tutorial but I am not sure how or if I can add my FeatureServer layer.
Would it be easier to use a map made on ArcGIS Online that uses the FeatureServer?
I also have a MapServer that I could use instead.
What would work the best and how would I go about doing it?
Thanks!
FreddieGibson
Honored Contributor
You can use a FeatureService or MapService as a layer in Runtime Java. For the FeatureService you'll want to take a look at the following sample.
https://developers.arcgis.com/java/sample-code/feature-layer/
The code you're looking for will resemble the following:
ArcGISFeatureLayer featureLayer = new ArcGISFeatureLayer(FEATURE_SERVICE_URL);
featureLayer.setName("Feature Layer (San Francisco incidents)");
map.getLayers().add(featureLayer);
For the Map Service you'll want to look at the following sample.
https://developers.arcgis.com/java/sample-code/map-layer-ordering/
ArcGISDynamicMapServiceLayer dynamicLayer = new ArcGISDynamicMapServiceLayer(MAP_SERVICE_URL);
dynamicLayer.setName("Dynamic Layer (Unemployment Rate)");
map.getLayers().add(dynamicLayer);
FreddieGibson
Honored Contributor
TedJacobi
Thanks I had found that once but for some reason couldn't again.
Another related question for the FeatureServer, if I have multiple features in the featureserver do I need to add a url for each one assigning it to a variable and then with the method:
      private void createGeodatabaseFeatureServiceTable()
          featureServiceTable = new GeodatabaseFeatureServiceTable( FEATURE_SERVICE_URL, 0);
Add a new featureServiceTable for each URL variable and id number?
EricBader
Honored Contributor
Ted,
One FeatureService URL can have multiple layer ids. Or, it can have just one.
Does this help?
