ArcGISRuntime setAppDataDirectory method
3607
06-01-2016 11:50 AM
LukeCatania
I am using Eclipse Mars Version 4.5.2.  I am trying to access the setAppDataDirectory on the ArcGISRuntime class, but it does not come up as a method.  the only methods that are valid are the static methods RenderEngine and License.  I have the import statement for com.esri.runtime.ArcGISRuntime.
VijayGandhi
I just tested ArcGISRuntime 10.2.4 with Eclipse 4.5.1. It worked.
Does it compile if you use the method? It should.
LukeCatania
Works fine.  It was a developer's memory fault issue.  Had the call outside my method.
