ArcGIS Runtime for Java 10.2.4 - com.esri.core.io.EsriServiceException:
15527
17
10-28-2014 06:47 AM
nita14
Hi All,
   I am trying to run a .gpk package with result map service (raster is an output). When I start my app, the Windows 7 window pops-up, telling me that the LocalServer instance has stopped working, and let me decide to stop or debug application. When I click stop, no service is going to be up and running. When I click debug and continue debugging in Visual Studio, another pop-up shows up informing me that it is unable to get stack info. Next, I check Server REST endpoint and see that the services are started (Geoprocessing service and associated Map Service). Any ideas, what is going wrong?
I use Eclipse LUNA and Java 1.8.0_20 on win7 Professional. Below, you find basic syntax of my geoprocessing task.
gpService= new LocalGeoprocessingService("path to gpk");
gpService
  .setServiceType(GPServiceType.SUBMIT_JOB_WITH_MAP_SERVER_RESULT);
gpService.startAsync();
Any suggestions are much appreciated,
Best Regards,
Adam
nita14
Hi Ryan,
Confirmed. I receive the same message. I know it is due to unhelded exception in ArcGIS Runtime. I traced the error using Microsoft Visual Studio 2013. This is information stack:
Unhandled exception at 0x0000000077AB4102 (ntdll.dll) in RuntimeLocalServer.exe: 0xC0000374: Sterta została uszkodzona (parameters: 0x0000000077B2B4B0).
First-chance exception at 0x000007FEFD7E940D in RuntimeLocalServer.exe: Microsoft C++ exception: ESRI::SensorModel::CSM::RequestedOperationFailedException at memory location 0x000000000224BD40.
HEAP[RuntimeLocalServer.exe]: Invalid address specified to RtlValidateHeap( 0000000002140000, 0000000002DFFE90 )
BTW: Do you use Lenovo as the development machine?
ryantan
Hi Adam,
I may find a work-around.
After tried any clue I can think of, I desperately thought since the exception is resident in the LocalServer native binary code, so I think if it's possible to try another native code. so I uninstalled my current runtime sdk(version 10.2.4), and installed an early version(10.2), then unexpectedly, I find my code and mpk file can working against 10.2 successfully!!!
I never really thing that is possible. but it seems every thing is perfectly working, I can get my dynamic layer displayed on a map. so I guess the developer of 10.2.4 must screwed something inside localserver 10.2.4.
I hope it can help you too.
BTW. yes, I'm using a Lenovo laptop as development machine 🙂
Best Regards,
Ryan
nita14
Hi Ryan,
I am glad you resolved this issue. However, the API downgrade is not an option for me. I use new functionalities added in 10.2.4. I do not have payed developer plan, so I can not officially report this bug to Esri. Now then, a number of Esri developers follows this workspace, so perhaps they will examine this error in more details in the next release.
BTW: I use Lenovo too. Maybe this bug is somehow connected with some hardware issues?
Anyway, good luck Ryan!
Regards,
Adam
ryantan
Hi Adam,
I'm very sad to hear it cannot help you.
I do think the issue is related to special hardware.
maybe you try a dedicated arcgis server to run your .mpk as a service if it's acceptable. I tested that solution, it can work with 10.2.4 sdk.
anyway hope you get ride of this issue very soon!
Regards,
Ryan
nita14
Resolved in Runtime 100.0.0
BKuiper
Hi adam, could i e-mail with you in private? I'm having a similar error with the Runtime for WPF on a Lenovo machine. I'm not sure what you mean with "Resolved in Runtime 100.0.0". As far as i know there is no version 100.0.0.
nita14
Hi Bjorn,
Indeed, there is 100.0.0 version for .Net as well.Please check ArcGIS Runtime SDK for .NET | ArcGIS for Developers . Also be aware that Local Server is now a seperate install. If you want to write me in private, I am available on firstnamelastname@hotmail.com.
Regards,
Adam
BKuiper
Ah, yes, i see it has just been released.. it is quite a step forward, from 10.x to 100.x. Anyway, we are not in a position right now to upgrade. So we have to find another way to resolve this issues. It definitely seems to be specific to the Lenovo (Thinkpad). You can remove your e-mail address (to prevent spammers). Thank you for your response.
