Arcgis java - anomaly in map - freezing or dissapearing
1963
04-21-2016 11:23 AM
AvivDinitz
I have a freezing/disappearing JMap problem.
I'm using the Arcgis for java developers for developing GUI. My main frame is java-fx application - stage and scene. On my scene I have couple of java-fx components. One of them is a corner small window StackPane with a SwingNode on it. The SwingNode contains a panel, which contains a JMap. On JMap I have tiled map something.tpk.
The code is here:
private void createAndSetSwingContent() {
UtilManager.getInstance().runInEDT(() -> {
JPanel mapPanel = new JPanel();
  mapPanel
.setPreferredSize(new Dimension(340, 290));
  map
= MapManager.getInstance().createMap(mapPanel);
  map
.addMapEventListener(new MapEventListenerAdapter() {
@Override
public void mapReady(MapEvent event) {
  mapReady
= true;
  graphicHolder
= new GraphicalIDHolder(map);
  mapPanel
.setVisible(true);
  setPanel
(mapSwingNode, mapPanel);
private JMap createMap(JPanel panel, MapType mapType) {
JMap map = new JMap();
  map
.getLayers().clear();
ArcGISLocalTiledLayer tiledLayer = new   ArcGISLocalTiledLayer("c:/PRIMUS.tpk");
  map
.getLayers().add(tiledLayer);
  map
.setExtent(new Envelope(3883000, 3777000, 3884000, 3778000));
GraphicsLayer graphicsLayer = new GraphicsLayer();
  map
.getLayers().add(graphicsLayer);
// adding fill picture above the map, below the other graphics
Envelope env = new Envelope(-20037508.3427892, -11070723.3593911,
20037508.3427892, 11070723.359391);
SimpleFillSymbol fill = new SimpleFillSymbol(new Color(0,20,41,90));
Graphic g = new Graphic(env , fill);//getFillSymbol());//fill);//
  graphicsLayer
.addGraphic(g);
  map
.setPreferredSize(panel.getPreferredSize());
  map
.setMaximumSize(panel.getMaximumSize());
  panel
.add(map);
return map;
My problem is: After some time, the map disappears and some random junk showed there. When I touch this small window, the map reappears. Sometimes it also freezes for a while.
This is really bad looking, and I need to fix it. Is this a known problem? Should I refresh/repaint my map from time to time? If so, how can I do it?
Really appreciate your help,
Aviv.
Tags (1)
