Antialiasing support
1873
03-10-2017 06:53 AM
KamilB
Does the ArcGIS runtime support map services with antialiasing enabled? When I publish such a map service using the Fast antialiasing setting I only get a grey background in my Java client app. Turning off antialiasing fixes it. Is there anything I can do to make antialiasing work?
nita14
Kamil,
First of all, can you provide details regarding your development setup? What version of runtime do you use? Do you host your MapService on ArcGIS Server instance or Local Server instance?
Regards,
Adam
