How do you set an application to login and get secure content from AGOL? There seems to be some documentation and a new Credential class in the beta, but I am not sure how to do this.
Hi Thomas,
here you are:
Portal portal = new Portal("http://www.arcgis.com"); UserCredential credentials = new UserCredential("LogiCaseSensitive", "PasswordCaseSensitive"); portal.setCredential(credentials); portal.loadAsync(); portal.addDoneLoadingListener(new Runnable() { @Override public void run() { if (portal.getLoadStatus() == LoadStatus.LOADED) { ListenableFuture<PortalUserContent> content = portal.getPortalUser().fetchContentAsync(); content.addDoneListener(new Runnable() { @Override public void run() { try { PortalUserContent myContent = content.get(); for (PortalItem item : myContent.getItems()) { System.out.println("item title " + item.getTitle()); } } catch (InterruptedException | ExecutionException ex) { Logger.getLogger(QuartzBeta2.class.getName()).log(Level.SEVERE, null, ex); } } }); } } });
More details on: Access portal content—ArcGIS Runtime SDK for Java (Quartz Beta) | ArcGIS for Developers
Regards,
Adam
Hi Thomas,
here you are:
Regards,
Adam
I am sorry I was not clear. I am interested in getting content that is assigned to a specific group in my organizational account and therefore I have two options. These are OAuth 2.0 authentication and app login. The only reference I can find is at Use OAuth 2.0 authentication—ArcGIS Runtime SDK for Java | ArcGIS for Developers . But, looking at the Quartz java API reference I can only find a class called Credentials for portal. In it, there is a setCredential from json string something like the code below. I am wondering if this is the way to use the client id and client secret for an app to login to AGOL to get secured content. If it is, I need to know how to format the json string so I can automatically get content. If this is not the way to do it I need some guidance.
I want to create an offline/online app but the content that get delivered to the application has to be secure and from AGOL. Any help is appreciated.
final Portal portal = new Portal("http://www.arcgis.com", true);
portal.setCredential(Credential.fromJson("")); /
Tom
Sorry, just checked my email.
Thank you so much.
