Adding a label next to static point on map
3894
02-08-2016 06:21 AM
AvivDinitz
I have static points on a map.
I use this code to draw them:
    point = GeometryEngine.project(longitude, latitude, mapSR);
    pointGraphic = new Graphic(point, symbol);
    graphicsLayer.addGraphic(pointGraphic);
The point is drawed on the map.
Now I want to add a label(?) to it - show under the drawn point it's longitude and latitude.
I can do it using text adding, but then when I resize the map, the text placement changes.
I want to put it like a label - let's say on the bottom right from the point.
I want it to be sensitive for zooming, and binded to the Point.
I read about dinamic labels, but it seems very complex for such a simple request.
How can I do this?
Thanks.
nita14
You can use TextSymbol and set offset accordingly. Another option is to use FeatureLayer (from SQLite local geodatabase), edit data with Labels set and enabled. I did not try the second approach, but it should work.
Hope this helps a bit.
Regards,
Adma
nita14
Regards,
Adma
