Path distance tool - Table as Vertical factor parameter
2923
9
07-06-2018 10:44 AM
JustinMcKissick1
Hello,
I have ArcGIS 10.3.1 and am trying to run a Least Cost Path analysis that incorporates Toblers hiking function; however, I am unable to load the .txt document as a table in the Vertical Table parameter in the Path Distance tool. Does anyone else have that issue or know a work around? or what i may be doing wrong that the tool does not allow me to even search for the .txt document?
thank you,
Justin
DanPatterson_Retired
https://community.esri.com/message/500313
Shaun Walbridge gives some code examples for what is expected.
Make sure your table is constructed as shown in the help topic
LiliTran
Hi Justin,
Apologies for the delay in our reply. We are working on directing you to the right person.
Thank you for your patience!
JustinMcKissick1
Sounds good. thank you very much for looking into it!
-Justin
JustinMcKissick1
Good morning Ms. Tran,
i was wondering if you have had a chance to review the issue I am having
with the Path Distance tool. I have a project for my class due soon and
could use some input.
thank you,
Justin
On Tue, Jul 10, 2018 at 11:41 PM, Justin McKissick <jmckissick83@gmail.com>
LiliTran
Esri Technical Support‌ - Hi, Could you please help answer Justin's question above?
JustinMcKissick1
Lili,
I still have not heard back, any chance you know how long it generally
takes for a response?
thanks
Justin
StefanKooi
I am experiencing exactly the same prblem, using the same version of ArcGIS...
LiliTran
Hi Justin & Stefan,
Apologies for the delay in our reply. We recommend that you contact Technical Support , and they should be able to assist you with your question there.
Thank you,
Lili
JustinMcKissick1
I tried, it because I’m just a student and doing a student project, it
will not let me ask esri support. Stefan, are you able too?
Justin
