Legend Unique Values
2631
11-28-2018 09:29 AM
Jennifer_Andrews
In my TOC, I have a layer named OH Conductor Original.  Within that layer are several conductor types.
When I set up my legend, I only want certain conductor types to be displayed in the legend (but all drawn on the map) but I have yet to find a way to exclude certain unique values.  Can this be done?
DanPatterson_Retired
short of reclassifying your data, the only other way is to convert the legend to graphics and delete the pieces you don't want (ungroup the graphics to get down to the individual element level, then you can regroup when you are done.
Jennifer_Andrews
Converting to graphics is the last thing I wanted to do since I have several maps to make and the legend will change with each one. I think I’ve found a work around though. I just figured there would be a better way to accomplish this as it seems like a pretty simple task.
Thank you for the response.
Jennifer Andrews
GIS Analyst
Craighead Electric Cooperative Corporation
870-336-4416
JacobBoyle412
You could add the layer again, symbolized as you'd as a separate layer to the service.
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
Jennifer_Andrews
Thank you for the advice. I believe this to be similar to what I ended up doing.
Jennifer Andrews
GIS Analyst
870-336-4416
