Attribute Assistant - Calling a value method in an expression
908
03-26-2020 10:48 AM
KhoaPham
I have the following Attribute Assistant rules
Is it possible to have a solution where I can combine the two rules to accomplish this scenario:
"When the TRANSMISSIONCODE field >0 populate the PRESSUREZONE field with "635", else populate the PRESSUREZONE field with the ZONEID value of the intersecting WaterPressureZone polygon"
Is it possible to call the INTERSECTING_FEATURE value method from within the expression in the second rule such as something like this:
IIF([TRANSMISSIONCODE]>0, "635", INTERSECTING_FEATURE|WaterPressureZone|ZONEID)
I did try the above but it doesn't work.  Just wondering if anyone has any ideas (no matter how wild, involving AA, or not, but maybe just might work) they could share....
Thanks in advance.
