I tried using the "Open" button and the "Add Data" button and navigating to my .bundle files in ArcMap, but neither of these recognizes .bundles files.
Any help please.
Solved! Go to Solution.
We found the way - Export Tile Cache with parameter "Storage format" - "EXPLODED"
where did you get it? the file format is associate with a variety of things including GitHub and stuff for mac's
I create a tile cache and try to open/see an individual bundle.
Mark
You can drop the complete cache into ArcMap or ArcGIS Pro - in this screenshot it would be called "TestCacheAspectRGB". If you're navigating down into the subfolders and seeking to display individual bundles at different levels, I don't believe we have a method for viewing single bundles. If that's what you're seeking, let me know and I'll double check.
Cody B.
Thank you for your response Cody,
I use a storage format "esriMapCacheStorageModeCompactV2"
Any try to drop any file or any folder (Root OR Layers OR _alllayers OR L(evel)X) I have the error
I don't suppose it would be this type of tile cache (never use them... just going by help)
Do you see any data in the corresponding folder in ArcCatalog? Any data that you can add to ArcMap should be visible in ArcMap.
Also I think the bundle files are a part of the Cache (Tile) folder. If you have access, try working with the entire cache folder.
Thank you, Jayanta.
I see the image
My question is how to view/preview the content with Desktop or whatever
If the item is not opening in ArcMap by drag-and-drop from ArcCatalog, try previewing it in ArcCatalog. Open ArcCatalog Window (not the one attached with ArcMap).
Select the desired item and Preview "Geography".
Does it display anything?
