Duplicate Rasters in Derived Mosaic Dataset after Synchronize Mosaic Dataset
319
06-08-2026 06:50 AM
Labels (3)
lah
Hi everyone,
I'm running into an issue with duplicate rasters appearing in a derived mosaic dataset, and I’m hoping to get some guidance on best practices, specifically around the Synchronize Mosaic Dataset tool settings.
Environment / Setup
  • Enterprise GDB (SQL Server)
  • Orthomosaics (COG) stored in S3
  • ArcGIS Pro 3.5.4 / ArcGIS Enterprise 11.5
  • Daily ingestion python script
Mosaic Structure
  • 3 source mosaic datasets, split by year (2024, 2025, 2026).
  • Each source mosaic dataset grows to ~15,000–20,000 rasters.
  • New orthomosaics are added daily.
  • A derived mosaic dataset combines the three source mosaics using:
    • Raster Type: Table
    • (following ESRI recommendations for scaling large collections)
Workflow
I have a script that:
  1. Checks S3 for new orthos
  2. Loads them into the appropriate source mosaic dataset
  3. Runs Synchronize Mosaic Dataset on the derived mosaic dataset
The goal is simple:
 - Add any new rasters to the Derived MDS that were just delivered to the Source MDS. My Derived MDS should just be an identical, combined version of my 3 Source MDSs.
Problem
The derived mosaic dataset is accumulating duplicate rasters over time.
  • There are no duplicate rasters in the source mosaics.
  • This suggests that something in the synchronize process is reintroducing or duplicating items rather than strictly appending new ones.
What I've Observed
  • Earlier, I had trouble getting the Synchronize Mosaic Dataset tool to detect new rasters at all.
  • After adjusting parameters, it now detects them, but I’m now seeing duplication issues.
  • Some parameters make the process take 8+ hours to complete - also not feasible.
  • When testing on a smaller subset of mosaics (~10-20), I can't reproduce the issue.
  • Here's what's running currently:
arcpy.management.SynchronizeMosaicDataset(
            in_mosaic_dataset=pDMDS,
            new_items="UPDATE_WITH_NEW_ITEMS",
            sync_only_stale="SYNC_STALE",
            update_cellsize_ranges="NO_CELL_SIZES",
            update_boundary="NO_BOUNDARY",
            update_overviews="NO_OVERVIEWS",
            build_pyramids="NO_PYRAMIDS",
            calculate_statistics="NO_STATISTICS",
            rebuild_raster="NO_RASTER",
            update_fields="UPDATE_FIELDS",
            fields_to_update="AquisitionDate;CenterX;CenterY;GroupName;ProductName;Raster;Shape;Tag;ZOrder",
            existing_items="IGNORE_EXISTING_ITEMS",
            broken_items="REMOVE_BROKEN_ITEMS",
            skip_existing_items="SKIP_EXISTING_ITEMS",
            estimate_statistics="NO_STATISTICS"
Question
For this workflow, where I only want to:
  1. Detect and add new rasters only to an existing derived mosaic dataset.
  2. Not reprocess or duplicate existing rasters.
What Synchronize Mosaic Dataset parameters should I be using?
Otherwise:
  • Is there anything specific to using derived mosaic datasets with the Table raster type that could cause re-indexing or duplication of referenced items?
Any guidance, examples of working configurations, or gotchas around Synchronize Mosaic Dataset in this type of architecture (Source MDS --> Derived MDS via Table Raster type) would be greatly appreciated.
Thanks in advance!
