Tabbing through graphics on the ArcGIS JavaScript Mapping application
2789
10-21-2015 10:46 AM
ParameswaranPalanivel
I would like to tab through each graphics present on the  map viewer for example, if there are  five text element on the map viewer I would like to use the tab key to tab through each text element so that the screen reader would read the description of the text element. I was trying to set the tabindex property for the point graphics on the map using the getNode() property of the graphics object like below
map.graphics.add(grTxtElement);
var lblElement=grTxtElement.getNode();
lblElement.tabIndex=1;
The tab key works in Chrome but not in IE. Any ideas or suggestions?
Thanks!
Param
