White window C# visual 2019 and sdk 100.7
1607
02-18-2020 07:44 AM
CavronJeremy
Hi. I work with Visual Studio 2019.  I have installed ArcGIS sdk to .NET and WPF. I mount references ArcGIS in my C# WPF Desktop project. I write map code. But when I execute my program, I have a white window with "powered ArcGIS" text on Bottom. But I Don't have map.
If I make GIS project is ok. But I would like create a WFP desktop project.
Have you got solution?
thank
JoeHershman
Could you post or attach the rest of the code.  What is shown is not enough to determine the problem.
-Joe
CavronJeremy
Hi and thank you for your help.
I've solved my problem. It was my firewall that was blocking the map from loading.
On the other hand I want to load a local map. a tpk file. But I have a blank page and no error messages with WPF project with C#.
in my cs file :
Map map = new Map();
Uri uri = new Uri(@"My_Absolute_tpk_file_path");
ArcGISTiledLayer tilLayer = new ArcGISTiledLayer(uri);
map.Basemap.BaseLayers.Add(tilLayer);
MyMapView.Map = map;
in my XAML file
 <esri:MapView x:Name="MyMapView">
            <esri:Map/>
        </esri:MapView>
I'm with Visual Studio 2019 and ArcGIS Runtime 100.7 Thank
CavronJeremy
Problem is solved. It was my tpk file who was protected.
I post code to load tpk file in WPF project
 TileCache cache = new TileCache("absolute_tpk_file_path");
// Use the tile cache to create an ArcGISTiledLayer.
ArcGISTiledLayer tiledLayer = new ArcGISTiledLayer(cache);
// Display the tiled layer as a basemap.
MyMapView.Map = new Map(new Basemap(tiledLayer));
thank. subject solved
