I downloaded 2.6 tutorial data but cannot see the data in arcgis
1929
10-28-2020 10:46 AM
MarkPaul
Hi,  I downloaded chapter tutorial data for ArcGis 2.6 but when I open arcgis and a new project, and click on the file, I dont' see the data even though the window indicates the data has loaded
AdenaSchutzberg1
Hell Mark,
Can you please indicate what tutorial you are using? Is it from a book? A website? Please share the title or URL.
Can you share a screenshot of what ArcGIS Pro looks like when the data is supposed to be loaded?
Adena
MarkPaul
Hi Adena, I am using GIS Tutorial for ArcGIS Pro 2.6. It's a book. When
it is supposed to be loaded the name of the tutorial is at the top of the
window. I was thinking that maybe I can get access to the data through
the portal.
thanks, Mark
AdenaSchutzberg1
Hello Mark,
Thank you! I see you are working with this book from Esri Press: Esri Press| GIS Tutorial for ArcGIS Pro 2.6 |
I've shared your question with the Esri Press space.
Adena
MarkPaul
Thank you!
Craig_Carpenter
Hi Mark,
I can help you with this.
Did you download the data and save it to your computer?
The exercise data for the book can be downloaded from ArcGIS Online here:
https://learngis.maps.arcgis.com/home/item.html?id=515b0894ef004b4c9d5f5fee497139b8
Click Open and the download will start.
Once it has downloaded, (probably to your downloads folder) click on the file setup.exe and click through the standard extraction process.
Then follow the instructions in the book for opening a project and using the data.
Let me know if you are still having trouble,
Craig
