changing scale bar in ArcGIS online
6064
10-07-2019 09:10 AM
JenniferRoma
When creating maps in ArcGIS online, I would like to see the scale bar in metres, not feet. How do I change this?
Robert_LeClair
Esri Esteemed Contributor
Yes, if you're an administrator to your site, then you can change the units from Imperial to Metric
Robert_LeClair
JenniferRoma
Thank you – it’s done!
Robert_LeClair
Excellent!!  If you would, please mark the answer correct if you feel that is correct to close the thread.  Thanks and happy mapping!
AdenaSchutzberg1
I want to add this for completeness: If you are not an admin, you can override the admin setting in your profile. See: https://doc.arcgis.com/en/arcgis-online/get-started/profile.htm#ESRI_SECTION1_DBAC184C26344633BB3A7B...
