HA multi-stage sync with object store cluster
792
11-28-2025 06:40 AM
SimonSchütte_ct
MVP Regular Contributor
I have a two stage system I have to update using WebGISDR, both are HA deployments.
(Workflow: Migrate to a new machine in ArcGIS Enterprise using the WebGIS DR tool)
In earlier releases there was the Tile Cache Data Store (Primary/Secondary).
Now the Object Store does not have a primary/secondary mode.
For HA a cluster of at least 3 machines are required.
When I try to export from Stage 1 and import in Stage 2 using WebgisDR with Object Store content included, it fails.
Instead of using the Object Stores from Stage 2 it will remove the Object Stores from Stage 2 and add the Object Store machines from Stage 1.
I could not find any information on this topic.
I expect the Object Store to behave the same in context of WebgisDR as the Tile Cache.
What do I have to do to import the data from Object Store Cluster Stage 1 into Object Store Cluster Stage 2?
What is the expected behavior/workflow?
Does anyone have experience using WebgisDR to sync Object Store Clusters?
SimonSchütte_ct
Looks like I am doing everything right, however there are a bunch of bugs with the Object Store: Solved: 11.5 - webgisdr - replication of objectStore broke... - Esri Community
Make sure the latest patches are installed on your system.
