how i can create Task Management Portal system by using arcgis
1416
03-17-2025 10:51 PM
Labels (3)
MajidaAlSalhi
Current Situation:
Currently, when we encounter system issues, we communicate with K&A via email. All follow-ups and status tracking are managed through email chains until the issue is resolved. However, this approach leads to inefficiencies, including delays in follow-ups and, at times, missed updates from both sides.
Proposed Solution:
We require a dedicated task management portal where all reported issues are logged, assigned, and tracked efficiently. The portal should streamline communication, enforce accountability, and ensure timely resolution.
Key Features:
  1. Issue Registration & Assignment:
    • Users can register system issues through the portal.
    • Each issue is automatically assigned to K&A and reflected on their dashboard.
  2. Issue Tracking & Status Management:
    • The vendor must update the issue status at each stage:
      • Pending: Issue reported but not yet addressed.
      • In Progress: The vendor has started working on the issue.
      • Resolved: The issue is completed, pending verification.
      • Closed: The issue is confirmed as resolved.
    • When changing the status to In Progress, the vendor must specify the estimated resolution time (date and time).
  3. Automated Notifications:
    • The system will send automatic email notifications to the user who registered the issue at each status change.
    • Reminders will be sent if no update is provided within the estimated resolution time.
  4. Mandatory Documentation Upload:
    • Upon resolving an issue, the vendor must upload a PDF report detailing the resolution process.
    • The issue cannot be marked as Closed until documentation is provided.
  5. Dashboard & Reporting:
    • A comprehensive dashboard displaying key metrics:
      • Total issues reported
      • Number of pending issues
      • Number of resolved issues
      • Issues that took the longest time to resolve
      • Issues resolved in the shortest time
      • Average resolution time per issue
      • Trends in issue occurrence and resolution efficiency
  6. Additional Enhancements:
    • Search & Filter Options: Users can filter issues based on status, date, or priority.
    • User Access Control: Different user roles (admin, reporter, vendor) with appropriate permissions.
    • Historical Logs: Maintain a record of all issues, updates, and actions taken for audit purposes.
This platform will ensure transparency, accountability, and efficiency in issue resolution while reducing reliance on email-based tracking
TracyMoy
If you have not seen this, do check out the Request Management Solution. It is amazing and very configurable.
GIS Request Management Solution
TracyMoy
The link below is a webinar of success stories from a couple of weeks ago, there is another webinar today around noon.
Webinar for Success stories: GIS Request Management Solution
