Widget Placement in ArcGIS API for JavaScript 4
2732
12-19-2018 11:01 AM
GavinRehkemper
Someone asked me recently: "how do I push the address search widget up above the zoom buttons?"
They were adding a Search widget to their application like this:
var searchWidget = new Search({
  view: view
view.ui.add(searchWidget, "top-left");‍‍‍‍
and they were getting a map that looks like:
I did a bit of searching, and found out that the JavaScript API has an option for this - in the second parameter of "view.ui.add()", instead of passing a string like "top-left", pass an object - and in that object you can control the "index" of where to place the component relative to other components:
view.ui.add(searchWidget, {
  position: "top-left",
  index: 0
So you'll get something that looks a little cleaner:
Full example is here - happy coding!
1 Comment
LeoLiu1
easy peasy, this is very helpful.
About the Author
I am a geospatial developer working for Esri Professional Services. https://gavinr.com ... see my Codepens: https://codepen.io/gavinr
