What's Within: When Esri + Clementini = User Beware
3445
05-15-2015 02:34 PM
JoshuaBixby
MVP Esteemed Contributor
0 4 3,445
This is the second in a two-part series on the risks to software users of poor documentation; specifically, the confusion and unexpected results that come from weakly documented spatial operators in GIS software.  The first part in the series looks at how inconsistent and incomplete documentation requires users to guess how spatial operators are implemented.  The second part in the series looks at the inconsistent results that arise from mixing different implementations of spatial operators.
One of the many empty geometry bugs I have submitted recently got put on the front burner this week when I noticed Esri updated the status to "Closed:  Will Not be Addressed."  What has ensued is a discussion that is still unfolding over expected behavior versus unexpected results.  Coincidentally, the issue can be framed neatly within the discussion and examples from the first post in this series (What's Within:  When (Esri != Clementini) = ?).
The first post in this series discussed how there is no singular definition of spatial relations for geometry libraries and geospatial applications, and how the Dimensionally Extended 9 Intersection Model (DE-9IM) became the prevailing 2D definition after inclusion in the OpenGIS Implementation Specification for Geographic information - Simple feature access - Part 1: Co....  The post focused on how incomplete documentation of spatial operators forces users to guess, and likely incorrectly at times, how software works instead of knowing how the software should work.  As unfortunate for users as incomplete documentation can be, mixing different definitions of spatial relations within the same spatial operator is much worse, and that appears to be what Esri has done.
Borrowing from the examples in the previous post, let's look at three features and the ArcPy Geometry.within() method.
>>> #Create square polygon
>>> polygon = arcpy.FromWKT('POLYGON((0 0, 3 0, 3 3, 0 3, 0 0))')
>>> #Create line that completely lies on polygon boundary
>>> line = arcpy.FromWKT('LINESTRING(1 0, 2 0)')
>>> #Create empty line
>>> line_empty = arcpy.FromWKT('LINESTRING EMPTY')
>>> #Test whether line is within polygon
>>> line.within(polygon)
False
>>> #Test whether line_empty is within polygon
>>> line_empty.within(polygon)
True
For comparative purposes, let's run the same two tests from Lines 9 and 12 using Esri’s ST_Geometry in Oracle:
SQL> --Test whether line is within polygon
SQL> SELECT sde.st_within(sde.st_geomfromtext('LINESTRING(1 0, 2 0)', 0),
                          sde.st_geomfromtext('POLYGON((0 0, 3 0, 3 3, 0 3, 0 0))', 0))
       FROM dual;
SDE.ST_WITHIN(SDE.ST_GEOMFROMTEXT('LINESTRING(10,20)',0),SDE.ST_GEOMFROMTEXT('PO'
SQL> --Test whether line_empty is within polygon
SQL> SELECT sde.st_within(sde.st_geomfromtext('LINESTRING EMPTY', 0),
       FROM dual;
SDE.ST_WITHIN(SDE.ST_GEOMFROMTEXT('LINESTRINGEMPTY',0),SDE.ST_GEOMFROMTEXT('POLY'
Interesting, the results from using ST_Geometry differ from using ArcPy.  Knowing that ST_Geometry functions are OGC simple feature access and SQL compliant, which means they implement DE-9IM, the results from ST_Geometry in Oracle are expected because a line solely on the boundary of a polygon is not considered within the polygon, and an empty geometry cannot be within another geometry.
When looking at ArcPy results, Line 10 is correct only if the ArcPy Geometry Classes implement Clementini's definition since we saw in the first post of this series that Esri's definition of Within is True in this situation.  Unfortunately, the ArcPy documentation doesn’t state one way or another which definition it is implementing.  The result on Line 13 is correct only if the ArcPy Geometry Classes implement Esri's definition because the Clementini definition does not allow for an empty geometry to be within another geometry.  Clear as mud, right?
Esri's stance, to date, is that everything is working as designed.  What?!  If that is the case, Esri is implicitly acknowledging they are implementing different definitions of a spatial relation within the same spatial operator, it just depends what geometries you pass it!!  Between the closed source code, incomplete documentation, and seemingly arbitrary implementation; ArcPy Geometry Classes are use at your own risk.  Caveat utilitor.
4 Comments
VinceAngelo
Esri Esteemed Contributor
I think the risk is assuming Clementini operators exist where no mention of "Clementini" is found.  Esri has supported a WITHIN operator since long before the Clementini paper was written.
The creation of SDE (at 3.0) provided a new opportunity to implement a spatial operators library, and Clementini was chosen to be the basis of that library. SDE.ST_GEOMETRY was implemented using that library, and OpenGIS adopted Clementini (probably at Esri's suggestion, though I'm not certain of that). I've got a copy of the Clementini paper (actually, I have several, one in each boot partition of every system I manage), and I use it to check for defects and cross-check for desired functionality, but the average user is not going to want a 2-hour lecture on geometry algebra (and another on geometry calculus) before using a theme-on-theme query tool.
Choosing to break existing functionality on upgrade is a dangerous endeavor.  The rules become even more slippery when additional functionality is added.  And Clementini treats a number of common topological relationships as multiple discrete cases, which would have removed functionality.  So, yes, there are multiple geometric relationship libraries within Esri code.  When you add in the absurdity of having an "empty line" discrete from an "empty point" and don't support a true "Nil" (which is a feature of WKT), then you've also got multiple conflicting standards to address. And that means that yes, there are multiple possible oddities when asking a computer to answer a nonsensical Boolean question.  Personally, I would return FALSE to all Boolean questions outside of defined behavior, but because it is undefined, any outcome, including a division by zero exception would be technically correct.
JoshuaBixby
Vince Angelo​, thanks for the comments, I know you have a long history with SDE and spatial operators.  Your background and perspective is always good reading, even if we aren't always in perfect agreement.
Regarding your first paragraph, I completely agree.  It seems I may have failed to put what was in my head down in writing.  When it comes to the ArcPy Geometry Classes specifically, which is really what I am selfishly most concerned about, I expected the Geometry.within() method to return the same results as the Select Layer By Location tool, but that isn't the case with a line on a polygon boundary.  With no reference to Clementini or DE-9IM, I expected to see results consistent with Esri's definition but the line on boundary results from Geometry.within() are consistent with Clementini instead.
DanPatterson_Retired
Vince ... got notes???
..... but the average user is not going to want a 2-hour lecture on geometry algebra (and another on geometry calculus) before using a theme-on-theme query tool.....
doing my sabbatical stuff so anything interesting pass on!!!
VinceAngelo
I do, somewhere, but they were part of the 'C' API training materials, so I can't give them away.
The Clementini paper itself ("A Small Set of Topological Relationships Suitable for End-User Interaction") formed the basis of my slides, with a table for the function calls and how they were defined with respect to features, boundaries, exterior, and interior.  I usually lost most of the students before the end, so I never went on the calculus-based method (CBM).  But I did design some exercises that could construct geometries from the command line, then test the various relationships possible (and those tools made their way into se_toolkit).
- V
About the Author
Former geospatial systems engineer in the federal government now working in state government as a geospatial hosting architect.
