Real-time Geodatabase Replication? Part 6
893
01-24-2015 12:26 PM
ThomasColson
2 0 893
In Real-time Geodatabase Replication? Part 1 you were introduced to SQL Real-Time Replication. One requirement of SQL Merge Replication is that the table being replicated must have a rowguidcol. This is easy with a cursor:
DECLARE
@sql VARCHAR(500),
@tableName VARCHAR(128)
DECLARE gandgCursor CURSOR
FOR
SELECT
table_name
FROM
SDE_column_registry
WHERE
table_name like 'CR%'
ORDER BY
table_name ASC
OPEN gandgCursor
FETCH NEXT FROM gandgCursor
INTO @tableName
WHILE ( @@FETCH_STATUS = 0 )
BEGIN
SET @sql = '
ALTER TABLE [dbo].['+ @tableName + ']
ALTER COLUMN GlobalID ADD ROWGUIDCOL ;
 PRINT 'Executing Statement - '+ @sql
 EXECUTE ( @sql )
 INTO  @tableName
 END
 CLOSE gandgCursor
 DEALLOCATE gandgCursor
About the Author
This is a personal account and does not reflect the view or policies of my org.
