Traditionally, there are three types of methods to fill voids in DEM like SRTM and InSAR, which are available in ArcGIS.
A method to fill voids uses a variety of interpolators; a method to determine the most appropriate void filling algorithms using a classification of the voids based on their size and a typology of their surrounding terrain; and the classification of the most appropriate algorithm for each of the voids in the SRTM data.
Obviously, the choice of void filling algorithm is dependent on both the size and terrain type of the void. Generally, the best methods can be generalized as:
However, on our practice, two latest methods (Fill and Feather method, Delta Surface Fill), which are only available in some leading Remote Sensing packages (below), are mostly recommended to do DEM/ DTM filling task in operation.
